Not sure if its an IE problem or an IE setting problem, but lately when running the Orion Web Console in IE9, I get many pop ups that state "A script on this page is causing your web browser to run slowly." Anyone else having this issue?
Yes I am having the same issue but in IE8. For us it seems to be with the new style resource charts such as Top CPUs by Percent Load and Network Latency & Packet Loss. There is also a thread below about it containing some fixes which i might try. Our node details pages are unworkable at the moment.
http://thwack.solarwinds.com/message/166539#166539
What version NPM are you using?
Any other modules other than NPM? Version?
Did you or are pointing to an external site through Custom HTML resource?
We have just upgraded to NPM 10.3.1 and SAM 5.2 along wil NCM 7.1, Storage 5.1.0 and UDT 2.5.1. Definately to do with the new fancy resources loading!!!
No external sites or resources or Custom HTML for us.
Seems like the fix in the thread above has fixed the issue I would suggest trying that first.
