I had a fault on a 460 switch yesterday whereby the 2nd of 3 units cascaded together went down, because this wasn't the management block nothing showed on the NPM map as being a fault, the switch was still pinging and if you used Java Device Manager you could view the switch except for the second cascade.
Does anyone know the MIB number for this switch and the OID that would allow me to see when a cascade goes unavailable so that I could set up some sort of alert to be aware of an issue like this. Better still if you have had the same problem and now found a way to be aware when this happens please let me know.
Thanks.
