Some of you have asked how I added the thwack quick launch resource to http://oriondemo.solarwinds.com. It shows you the last few posts and lets you search quickly from inside Orion, opening a new window with Thwack so you don't loose your place in Orion. It's easy to set up, and if you like it let me know.
Setup:
- Log in as admin
- Click the "Admin" link in the tool bar
- Click "Manage Views"
- Select the view you want to add the resource to and click "Edit"
- Click the "+" button to add, then expand miscellaneous, check "Custom HTML or Text" and click "Submit"
- Go to the view you just edited, scroll to the Custom HTML resource and click the edit box in it's title bar.
- Set the Resource Title, (I thought "SolarWinds User Community" was just the ticket)
- Set the custom HMTL or text to this:
<iframe id="thwack" src="#THWACK URL#" width=450 height=450 marginwidth=0 marginheight=0 hspace=0 vspace=0 frameborder=0 scrolling=no></iframe>
Replacing #THWACK URL# with:
- http://thwack.com/orion/OrionThwackResource.aspx for new threads in the Orion forum or
- http://thwack.com/orion/ThwackPortal.aspx for new threads in all forums
You'll also want to adjust the width to match your column width and the height to whatever you like, 450 is my default.
- Click "Submit"
I've got some ideas to improve it and would love to hear your feedback.
Cheers,
Patrick
