I have recently started using an APC AP9335T temperature probe to monitor cabinet temps.
As I am new to the solarwinds community I am unsure as to how I should go about adding this probe to solarwinds.
What you will need to do is use the MIB from APC to create a custom poller. From there you can assign that poller to the device. You can create the poller in the Universal Device Poller application on your solarwinds server. You can even assign it to your device from inside of there.
I believe this should help walk you through on how to do this:
Create a Universal Device Poller
Are you referring to creating a custom poller to monitor the temperature?
Yes, I am using the apc external probe connected to a 9631network management card
Thanks for the good info and timely response!
