The following three screen shots are from a server with the following essential specifications:
- a VM with 4 CPU cores and 16 Gb RAM
- Polling cimpletion is at or near 100% consistently
- Polling rate is 41%
However, the server CPU utilization has consistent spiking issues.
Any suggestions for addressing the CPU issue will be appreciated. I should mention that the end user is hesitant to add any more CPU cores to the VM. Would RAM help? Thank you.
