We encountered 100% CPU utilization in one of our Polling Engine.
We check the task manager and Job Engine Workerv3 contribute a very high response.
Tshoot done:
1. We do this already: Re: High CPU usage on Solarwinds server, Solarwinds Information Service V3 using 100% CPU, empty groups.
2. Start and Stop services
3. Restart the server
See below screenshot from Polling Engine Settings
How's the polling interval going?
And if you're already on Core 2015.1.x, have you tried applying the Orion Core HF6?
Try going for Orion platform 6 if possible.. It has resolved many issues specially with respect to high CPU and MEM utilization.
I mean hotfix 6
Big help guys.
As of now we created support ticket to troubleshoot this problem.
I'll inform once the problem resolve.
Thank you.
Awesome! we're very interested in the resolution. Please let us know how it goes
This could also be due to low specifications on the actual system . See minim requirements for APE hardware .
Plan your production deployment
Make sure its Quad PHYSICAL Sockets (NOT Virtual Cores )
[JUST SHARING]
Hi Guys,
Already resolved.
See below work around
- stopped all services
- Disable UAC, run comparability test - repair JE1 - replace JE2 and collecter Sdf. - uninstall and reinstall JE1. - Start all services, ensure PE up and running - monitored CPU for 10 mins seems ok.
Here is the KB just in case
http://knowledgebase.solarwinds.com/kb/questions/1377/Replacing+a+Job+Engine+Database
