How to set an alert for group of nodes for cpu and memory thresholds
Here is a good document covering your request. You will need to modify the trigger section as necessary for CPU and memory: https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/Create_a_Group_of_Nodes_alert_using_a_Custom_property_to_Identify_Group_name_and_Group_Member_Name_With_Variables
I followed this document only. In the fig 4 of this document, you are saying the status of group to be up or down. I would like to set the threshold alerts of the group members.
for ex: condition should be like this if the cpu exceeds 70% it should alert me. how do I do that.
Thank you in advance
We have made significant improvements to node thresholds, including allowing thresholds to influence the status of the node, and therefore a group. For more information, please see the following post.
Orion Platform 2019.2 - Enhanced Node Status
This is a dead link.
alphabits wrote:This is a dead link.
alphabits wrote:
Is this better? > https://support.solarwinds.com/SuccessCenter/s/article/Create-a-Group-of-Nodes-alert-using-a-Custom-property-to-Identify-Group-name-and-Group-Member-Name-With-Variables
Thank you!
@aLTeReGo
This link requires a login. My support login doesn't work. Any way to make it public?
Steve
