Hello all,
When I attempt to run the Orion Network Atlas I am getting the following error:
I check the log file for the application at the following path:
C:\Documents and Settings\All Users\Application Data\SolarWinds\NetworkAtlas
here is what I see...
2011-11-01 15:56:39,741 [1] WARN NetworkAtlas - Starting Network Atlas version 1.2.1.167
2011-11-01 15:57:11,897 [5] INFO MapEngine - Map MapEngine started.
2011-11-01 15:57:16,132 [5] INFO NetworkAtlas - Custom properties: 0
2011-11-01 15:57:16,147 [5] INFO MapEngine - Reading top level entities
2011-11-01 15:57:37,397 [5] INFO MapEngine - Get Available Maps Execution time: 00:00:21.0030001
2011-11-01 15:57:37,600 [Main Window UI thread] FATAL NetworkAtlas - UNHANDLED EXCEPTION CAUGHT ON UI THREAD.
2011-11-01 15:57:37,616 [Main Window UI thread] FATAL NetworkAtlas - Message: Property Status cannot be assigned from type Int32
2011-11-01 15:57:37,616 [Main Window UI thread] FATAL NetworkAtlas - Data: System.Collections.ListDictionaryInternal
2011-11-01 15:57:37,616 [Main Window UI thread] FATAL NetworkAtlas - TargetSite: Void BeginProperty(System.Xml.XmlReader)
2011-11-01 15:57:37,663 [Main Window UI thread] FATAL NetworkAtlas - StackTrace: at SolarWinds.InformationService.Contract2.EntityCollectionResponseParser`1.BeginProperty(XmlReader reader)
at SolarWinds.InformationService.Contract2.EntityCollectionResponseParser`1.ReadNextEntity(XmlReader reader)
at SolarWinds.InformationService.Contract2.InformationServiceQuery`1.<GetEnumerator>d__0.MoveNext()
at SolarWinds.MapEngine.Engine.ParseTable(IEnumerable`1 mngEntities, Entity entity, NetObject parentNetObject)
at SolarWinds.MapEngine.Engine.ReadEntityData(Entity entity)
at SolarWinds.MapEngine.Engine.ReadTopEntities(Action`2 progressReportCallback)
at SolarWinds.MapEngine.Engine.GetTopEntities(Action`2 progressReportCallback)
at SolarWinds.MapStudio.Gui.MainWindow.ReadTopData(Action`2 progressReportCallback)
at SolarWinds.MapStudio.Gui.MainWindow.startupBackgroundWorker_DoWork(Object sender, DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
2011-11-01 15:57:37,663 [Main Window UI thread] FATAL NetworkAtlas - Source: SolarWinds.InformationService.Contract2
Any one have any have any solutions for this one?
Many thanks!
Bryan
APM 4.2.0,
NPM 10.1.3,
IVIM 1.1.2
