First the upgrade Finished with Database configuration failed:
• Failed to initialize the Common Language Runtime (CLR) v2.0.50727 with HRESULT 0x80004005. You need to restart SQL server to use CLR integration features.
But Orion seems to work. The website is up, although a bit slower, and devices are there. But there is another issue. When trying to manage multiple devices under Admin and Manage Nodes an error comes up:
Server error: The communication object, System.ServiceModel.Security.SecuritySessionClientSettings`1+ClientSecurityDuplexSessionChannel[System.ServiceModel.Channels.IDuplexSessionChannel], cannot be used for communication because it is in the Faulted state.
The repair did not fix the problem. Neither did updates to .NET or reinstall of SQL SP2. We are using SQL 2005 on a dedicated box. I opened a case and provided diagnostics but no luck so far. Has anyone ran into similar issues?
