quote:Originally posted by azevJust installed a new SQL 2005 server with default setting, and I am having problem connecting to it from a new installation of orion...can someone here write a simple walkthough of what need to be done to connect orion to sql 2005 ?When trying to connect to sql server via the configuration wizard, I am getting an error that sql server can only be access via management studio. How do you solve this issue?Thanks
quote:Originally posted by vaibhav14 quote:Originally posted by azevJust installed a new SQL 2005 server with default setting, and I am having problem connecting to it from a new installation of orion...can someone here write a simple walkthough of what need to be done to connect orion to sql 2005 ?When trying to connect to sql server via the configuration wizard, I am getting an error that sql server can only be access via management studio. How do you solve this issue?Thanks
