Hi I have been given a request to monitor the following Cisco Cli command outputs. We are going to add new traffic to the Cisco Cubes and we need like to get a base line to see if we have the capacity to add the new traffic. But it very difficult to obtain the information and Cisco is not much help. I was able to get Call leg incoming and outgoing and total calls handled.
I have try to create a custom poller to add to the Device view , the OID I am searching only give you a peice of the information needed. Show call History details and sip history is what I am told is needed.
Any Help / Suggestion would be very appreciated.
Mike Lucci
| 1: Call Rate | 1 | 3 : MAX Value | 1:secondStats | 01-60 | READONLY | show call history stats cps |
| 2: Call Leg Rate | 4: Average Value | 2:minuteStats | 01-60 | READONLY | show call history stats cps detail |
| 3: Connected calls | | 3:hourStats | 01-72 | READONLY | show call history stats connected |
| 5: SIP message rate | | | | | show sip-ua history stats message-rate |
| Equivalent CLIs |
Cisco Cube info
| | Machine Type | | Cisco 3945SPE250 |
| | System Name | | flen-cube1 |
| | Description | | Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.3(3)M3, RELEASE SOFTWARE (fc1) Technical Support: www.cisco.com/techsupport Copyright (c) 1986-2014 by Cisco Systems, Inc. Compiled Tue 27-May-14 23:45 by prod_rel_team |
