I have a request to produce from solarwinds the application / components configured in SolarWinds database. I know there is report writer and accordding to my architect he wants the same raw data that Report Writer uses.
any help ?
Easiest way is to grab a report from the report writer, then in the menu go to Report, Show SQL. This will show you the SQL behind the report that your architect can then use to query the database directly.
