Hello,
I have a client which did a POC/Test of NPM on their own. They used the embedded SQL for the db during the testing. They decided that they would like to purchase NPM and asking if is it possible to migrate the contents of the embedded SQL into an external SQL so that they would not lose the data captured during the testing.
If it is possible what are the steps to be taken?
Do I only need to install a Management Studio on the server? What should be the credentials for the embedded sql? Thank you.
