Is there a way to adjust how many group members have to be down before a group shows warning / down? Same for how many interfaces have to be down before a node shows down or warning?
Thanks!
From what I can tell, I'd assume it's more than half have to be down if your group is set to show mixed results. The only option I can see is the show worst case when you edit the group under the Advanced Settings. There isn't a place to adjust how many devices have to be down.
Regards,
Matthew Harvey
Loop1 Systems
No.
[the percentages are what is used for availability calculations involving the group, so if you have one out of ten nodes up in a mixed-status group then the availability of the group for calculations is 100% and the status is Warning. ]
Availability calculations at anything other than the Node level are fraught with difficulty (e.g. how do you cope with availability of the subnet when it's supported by two routers with HSRP/VRRP configured)
