I am seeing this in the logs around once every 5 minutes through the day normally when a laptop is unplugged from a Cisco IP phone. How do I suppress this alert in solarwinds?
Interface Speed changed from 10000000 to 100000000 bps
you can disable this event globaly for whole environment directly in the database by setting the 'Record' field of this particular event type to False. But you won't be informed about any interface changes then. Following script should do the trick:
UPDATE EventTypes
SET Record = 0
WHERE Name = 'Interface Changed'
Hope this helps,
Zbynek Botlo
