I am currently installing the NPM and NCM platoforms to manage a Juniper and Tellabs network and would like to know if I can monitor the Tellabs 709 down to the port level to see the rx/tx traffic generated by the port.
Does this device support the standard If-Mib ?
If yes, then try to list the resources of this equipment in NPM and select the interfaces you need to monitor.
if no, Did Tellabs manufactured his device to support alternative MIBs ?
If you are not sure if it supports the standard If-MIB, list the resources. if that does not work, review the configuration of your device and try to run a MIB walk starting on the following OID: 1.3.6.1.2.1.2 .
If the device supports alternative MIBs, you can setup Universal Device Pollers in NPM to monitor required OIDs.
HTH,
Yann
