Hello together,
here some info regarding the use of a reverse proxy to access the
orion webconsole. As well, as some questions and 'improvements'
for 'better code quality by solarwind'.
For customer a scenario is needed:
https://<domain>/solarwind -> http://<internal IP>:20080
while under the internal IP Solarwind Orion is running.
Now, I used Apache 2.2.11 as a reverse Proxy with
mod_proxy and mod_proxy_html modules.
The proxy configuration is:
ProxyPass /solarwind/ http://172.23.56.1:20080/
ProxyHTMLURLMap http://172.23.56.1:20080 /solarwind
<Location /solarwind/>
ProxyPassReverse /
ProxyHTMLURLMap / /solarwind/
ProxyHTMLURLMap /solarwind /solarwind
ProxyHTMLURLMap //<![CDATA[ <!--<![CDATA[-->
ProxyHTMLURLMap //]]> <!--//]]>-->
ProxyHTMLURLMap //--> <!--//-->
ProxyHTMLURLMap // <!---->
RequestHeader unset Accept-Encoding
RequestHeader set Referer http://172.23.56.1:20080/
</Location>
This will work to show the GUI partly. Now comes the first trick
to avoid errors by bad programming (sorry solarwind...).
While some images and scripts are refered through an 'unknown'
(maybe the solarwind own ISAPI Proxy Rewrite dll) mechanism,
they will not load. So create under your apache documentroot a
copy of the solarwind install folder from IIS inetpub, and refer to
it with:
Alias /Orion
/ServerApplications/SolarWinds/Orion
<Directory
/ServerApplications/SolarWinds/Orion>
Order allow,deny
Allow from all
</Directory>
This fixes some problems, mainly with css and images.
The second bad code parts are the In-Script comments used,
e.g. //<![CDATA[. I showed a way to rewrite them in above
proxy configuration. But there are still some left.
Use FF error console to find them.
The last error will occure, when you want to see the nodes.
Then the server will bring up an error 'Server error: The server
method 'GetTreeSection' failed.'. This function seems also be
used when selected 'Overview'. You CAN show without problems
the single nodes. This seems working.
Maybe another user has some hints to avoid above mention
problems. Mainly the problem with the Server error.
(Use of apache is needed, no other proxy server will be available)
best regards
