Hi All,
Just wondering if anyone has figured out a good way to monitor command line output for a device so you can alert non thinks that are not exposed via SNMP. As i'm sure we all know there are things even the newest and most expensive Cisco devices don't expose with SNMP. One such example is the output of the command "sh module" we are trying to figure out if we could use a combination of the credentials we already have in NCM to run this command and then parse the output to look for errors an alert us to an issue via NPM.
Any help or suggestions appreciated
Jon
