Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Cisco Switches Not Showing up correctly.
FormerMember
I have problems adding our cisco switches to the NPM. Some of them will be added correctly, however others will get added via IP address and then will somehow no longer keep their name as the IP addy.
The above shows how it becomes renamed as a blank space in the database, I am *NOT* renaming it, it just automatically becomes a blank. This results in the following on the website.
Sometimes I can rename the item via the console which will force it to work, however sometimes it will not rename at all and just stays as a blank space. I have uninstalled Orion and the databases and recreated them from scratch and this still occurs, I have also applied the 3 patches from the sticky.
I spoke to someone from tech-support however they did not give me a case #. Please advise.
Find more posts tagged with
Accepted answers
All comments
FormerMember
3/14/2007 09:13 AM Added 10.50.16.30-short wave fiber gigabit ethernet
3/14/2007 09:13 AM On node 10.50.16.30 interface name was changed from short wave fiber gigabit ethernet to Port 2/49 ? short wave fiber gigabit ethernet
Event log shows that it was added by IP address. If I repoll the device it will show the name as the IP and The correct IP, however the device still shows incorrectly in NPM and Website.
FormerMember
Bump, still need any input on this. This is occuring with the latest build of NPM.
chris.conway
The name usually comes from the prompt on the switch.
Make sure this is set correctly.
Alternatively, you can rename the node inside Orion to show the correct details.
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
FormerMember
Telnetting to every switch in our enviroment the Prompts are IP address>
ex 10.50.48.5>
I am also unable to rename the device.
FormerMember
Issue is still occuring, The very first switch I have added to a brand new blank database and it does the same as above.
You can see the database is not being properly populated,
This occurs in both MSDE and MSSQL Express databases.
aLTeReGo
Could this be because periods are illegal characters in the hostname? This is perfectly legal in a FQDN but hostnames cannot contain periods. Maybe the developers didn't envision anyone using the IP address as the hostname of their switches. Just a thought.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
