Hello,
I added a device(RND) to NPM but the problem is that can´t get CPU and Memory and I didn´t found any poller for this.
Someone can help me please?
Tf you add how snmp or agent ,please look list resource of the node and see check box cpu and memory.
Hi, I add this for SNMP and the list resource don´t appear the box for cpu and memory,
This likely means that the CPU and Memory metrics (OIDs) are not exposed by the vendor or are not where they are expected.
You could use an SNMP walk or ask the vendor for docs that outline the CPU and Memory OIDs and then use that info in device studio to add the relevant info to the poller:
Change device details in the Device Studio - SolarWinds Worldwide, LLC. Help and Support
