I would like to reset/clear the rogues listed in the Orion Wireless view. Is there any way of doing this to 'refresh' the list?
Yes, you are right. It is static from the controller.
I was hoping I could keep it more dynamic by time periods or something. Thanks.
We are getting this list directly from the controller, so if you update this on the controller, that should be reflected in Orion. Is this now what you are seeing?
