Hello,
I'm in the process of documenting an upgrade path for our NPM 8.0.67 with the Broadband Modem Management and CMTS module. I understand that those modules are no longer supported so my thought was this:
PtoV the current NPM frontend node, and then remove everything out of it but the CMTSes and cable modems.
Uninstall the modules from the 8.0 NPM server.
Upgrade to 8.5.1
Upgrade to 9.0
Upgrade to 10.0
Does that sound like a correct upgrade path? I would probably clone my DB as well just so I don't touch my current production DB.
Has anyone done an upgrade from 8.0 to 10.0 yet? Feedback appreciated!
Chris
