Trying to install SP3 on additional SLX polling engine, it stops the services and copys the files but then reports the following error and exits after restarting the services.
ERROR: The system was unable to find the specified registry key or value.
Starting Services
Has this actually updated the additional poller or not? Main server updated fine.
Edit - looking through the install log it would appear it ran twice - first time reported running fine but configuration wizard did not run 2nd time reported the error above. Have just run the configuration wizard manually and all looks to be OK so far...
