OK, so I have gone through the posts and see a number however there is nothing absolute when it comes to Cisco serial reporting. It seems that switches specifically respond to different OID than the routers. I am trying to get proper output from Cisco 3750 Stack switches and it seems if you do snmpwalk and try to list all serial numbers and models in a stack the successful output is something like this... x001,y001,z001 for both chassis type and serial numbers with each corresponding to relevant stack members. I can query this from command line and get result just fine however this does not work from Orion although entering 1.3.6.1.2.1.47.1.1.1.1.11 does work for routers.. A side not I see entries where people have been able to get custom pollers to list in reports however we are running 9.0sp2 and in report writer "universal poller" is not an available option.. Any help appreciated...
SNMP walk output... Trying to get the same in orion and output to report writer...
SNMPv2-SMI::mib-2.47.1.1.1.1.11.1001 = STRING: "FDO1229xxxx"
SNMPv2-SMI::mib-2.47.1.1.1.1.11.2001 = STRING: "FDO1229yyyy"
SNMPv2-SMI::mib-2.47.1.1.1.1.11.3001 = STRING: "FDO1229zzzz"
SNMPv2-SMI::mib-2.47.1.1.1.1.13.1001 = STRING: "WS-C3750-48PS-S"
SNMPv2-SMI::mib-2.47.1.1.1.1.13.2001 = STRING: "WS-C3750-48PS-S"
SNMPv2-SMI::mib-2.47.1.1.1.1.13.3001 = STRING: "WS-C3750-48PS-S"
