Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
View Limitation and Custom Mib Poller Summary
FormerMember
I have a Node Summary view that I have created to show all of our UPS devices. I have a view limitation using a Node Name Pattern *-UPS*.
This works perfectly. The view is limited to just our UPS' and shows only the node list, the last 50 events and the last 100 syslog messages from our UPS devices. This is especially important because Last 50 events DOES NOT support the filtering feature found on many of the web components.
My problem is that I wanted to include the battery status for each device using a custom mib poller. The poller works fine in the configuration, it displays fine on the node details for each UPS, but, on the above summary view I get the error SQL Open Error: Incorrect syntaxt near the keyword 'Where'
If I take the view limitation out it works fine but all of my nodes are in the view which defeats the purpose.
Anybody else seen this or have a resolution?
Find more posts tagged with
Accepted answers
All comments
ewattnem
You're not the only one
Check this out
http://www4.solarwinds.net/SolarWindsForum/topic.asp?TOPIC_ID=3325&SearchTerms=SQL,Open,Error
It's a bug.
What I did was made a seperate UPS login that only displays the UPS custom pollers. It's a pain but works for me.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
