I don't want to monitor my wireless environment through NPM. I noticed that my wireless devices are showing up under the wireless tab. How do I disable this so that NPM doesn't monitor them under this tab?
On your wireless controllers, List Resources, and un-check the "wireless controller" resource (usually listed after all the interfaces). that should remove all the wireless info for you.
