Hi
Since I upgraded Solarwinds I am unable to discover my Aruba AP's?
I have re-added the Aruba Controllers but the AP's no longer show?
Any idea's?
Jantzen
Unfortunately not a known issue. Support ticket may be the best way to go: SolarWinds Customer Support - We're Here to Help
I have found a fix!
To fix, please stop all Orion services. Then please change this file:- c:\Program Files (x86)\SolarWinds\Orion\APM\SolarWinds.APM.Probes.dll.config - - Find the <WmiSettings> section and change the ConnectOptions from "BothAutoCorrectedFirst" to "Default".Then run the Permissions Checker- Navigate to C:\Program Files\Solarwinds\Orion- Find executable OrionPermissionchecker.exe- Run this exe- If there are permissions error press repairAfter running the checker give it about 5 minute and run the checker again.
Could you add the software versions of NPM (and UDT) to your post -- we've an extensive Aruba install (almost 10,000 wireless APS's) and they are being discovered OK (through polling the controllers) with 10.6.1
