I have upgraded to 8.5 and applied the hotfix. However, strange things still going on. I already tried the "Rename \Inetpub\Solarwinds\Orion\custom.config.txt to custom.config" trick - that didn't solve anything. In fact, when leaving the file name to the latter, I couldn't log in. So the file is still called custom.config.txt (replaced localhost with IP though).
To re-manage unmanaged objects, I have to make a resource list first.
A customized view with a big map on the left and other stuff on the right, shuffles around so that I get the "right stuff" above the map.
When trying to edit account limitations, I get this error:
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.ArgumentException: An entry with the same key already exists. at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource) at System.Collections.Generic.SortedList`2.Add(TKey key, TValue value) at Orion_Admin_EditDefaultNetObject.OnInit(EventArgs e) at System.Web.UI.Control.InitRecursive(Control namingContainer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
