Is there anyway to remove the login? I'd like to be able to get to my Orion home screen without having to use a name/password. Thanks.
For Orion ver 8.5.1 see Appendix D of the Orion Administrators Guide
That was helpful....
There are three ways to do what you are asking, and the are all covered in the Admin Guide.
You can also use the search function in the forum:
http://thwack.com/search/SearchResults.aspx?q=Windows+Pass-Through+Security&o=Relevance
http://thwack.com/search/SearchResults.aspx?q=DirectLink&o=Relevance
http://thwack.com/search/SearchResults.aspx?q=URL+Pass-Through&o=Relevance
It might be less reading to look in the Admin Guide for the version of Orion you are currently running.
