I'm attempting to monitor the Checkpoint SNMP extension which runs on port 260. In order to add the node to NPM monitoring, it requires snmpwalk to return values, however, cpsnmp requires you to define a before it will respond (details below).
Is there a way to define a Node and OID to monitor without being able to walk the device?
THANKS.
I'd like to monitor the following:
[zawya001@netutil01 ~]$ snmpwalk -v 1 -c public 10.192.254.91:260 1.3.6.1.4.1.2620.1.1.25.3
SNMPv2-SMI::enterprises.2620.1.1.25.3.0 = INTEGER: 131572
However to add a node to NPM, it requires snmpwalk to return values...which fails without the firewall MIB-Branch:
[zawya001@netutil01 ~]$ snmpwalk -v 1 -c pubilc 10.192.254.91:260
SNMPv2-SMI::enterprises.2620.1.1.1.0 = STRING: "Installed"
SNMPv2-SMI::enterprises.2620.1.1.2.0 = STRING: "policy_infwcp10-cl.woc"
SNMPv2-SMI::enterprises.2620.1.1.3.0 = STRING: "Wed Dec 15 16:14:14 2010"
SNMPv2-SMI::enterprises.2620.1.1.4.0 = INTEGER: 826709229
SNMPv2-SMI::enterprises.2620.1.1.5.0 = INTEGER: 32
