Hi there,
I have a whole bunch of 2811s that I am sending almost 100% of our traffic through the onboard crypto engine. I have some sites with more bandwidth than others and I need to monitor the crypto engine to determine if its overloaded/dropping packets. I also have 7200s with SA-VAM2+ doing the same thing.
It would be great if this could be collected via snmp but the only way I have found is via the command "show crypto engine accelerator statistic"
</code></div><div class="line number3 index2 alt2"><code class="text plain">Device: NETGX
</code><code class="text plain">:Statistics for encryption device since the last clear
</code><code class="text plain">of counters 3432641 seconds ago
</code><code class="text plain">808722334 packets in 808650062 packets out
</code><code class="text plain">368108617535 bytes in 367973730758 bytes out
</code><code class="text plain">235 paks/sec in 235 paks/sec out
</code><code class="text plain">857 Kbits/sec in 857 Kbits/sec out
</code><code class="text plain">389962806 packets decrypted 418687256 packets encrypted
</code><code class="text plain">127542676560 bytes before decrypt 240338168075 bytes encrypted
</code><code class="text plain">108835368258 bytes decrypted 259138362784 bytes after encrypt
</code><code class="text plain">0 packets decompressed 0 packets compressed
</code><code class="text plain">0 bytes before decomp 0 bytes before comp
</code><code class="text plain">0 bytes after decomp 0 bytes after comp
</code><code class="text plain">0 packets bypass decompr 0 packets bypass compres
</code><code class="text plain">0 bytes bypass decompres 0 bytes bypass compressi
</code><code class="text plain">0 packets not decompress 0 packets not compressed
</code><code class="text plain">0 bytes not decompressed 0 bytes not compressed
</code><code class="text plain">1.0:1 compression ratio 1.0:1 overall
</code><code class="text plain">Last 5 minutes:
</code><code class="text plain">158594 packets in 158506 packets out
</code><code class="text plain">528 paks/sec in 528 paks/sec out
</code><code class="text plain">1420127 bits/sec in 1422918 bits/sec out
</code><code class="text plain">18559180 bytes decrypted 29269415 bytes encrypted
</code><code class="text plain">501599 Kbits/sec decrypted 791065 Kbits/sec encrypted
</code></div><div class="line number30 index29 alt1"><code class="text spaces"><strong>pkts dropped: 72272</strong>
</code><code class="text plain">fw_failure: 0 invalid_flow: 0 netgx sessions: 2
</code><code class="text plain">ownership_err: 0 null_data: 0 reqId mismatch: 0
</code><code class="text plain">fw_qs_filled: 0 fw_resource_lock:0
</code><code class="text plain">tx_hi_drops: 0 pak_too_big: 0
</code><code class="text plain">pak_mp_length_spec_fault: 0
</code><code class="text plain">Interrupts: Notify = 0, Reflected = 0, Spurious = 0
</code><code class="text plain">ring limit:64 current desc used: 0 current ring index: 34
</code><code class="text plain">wait session queue: 0 msg session buf queue: 1024
</code></div><div class="line number38 index37 alt1"><code class="text plain">
So I really want to see this somewhere that I can create an alert on it and add it to my dashboard. Unfortunatly I dont think there is any easy way to determine the "Load" on the crypto engine. From my understanding though if its dropping packets its overloaded.
