Is it possible to monitor Wireless SSID status and generate alert if SSID is not working or users are not able to connect to that SSID. I have NPM, SAM, NCM, netflow and other modules.
Is anyone here monitoring their SSID's ???
max348,
I guess the first question is, how do you currently determine an SSID is not working correctly? And the second question is, how do you determine a user is not able to connect? If you are using Cisco Wireless Controllers (and I assume others can do this too), you can configure it to send Syslog messages to NPM, and alert on those messages you want. Beyond that, I need some more specifics on what you are actually trying to achieve.
D
