Is anyone monitoring RHEL7 boxes with NET-SNMP and if so are you getting correct or even normal looking data for Memory Used/Memory Available?(Not Volume statistics) I recently noticed that all of our RHEL7 boxes are showing 0% for Memory Used/Available and when I look further at the box or pull it up in Perfstack the values are very much negative. Going through the SolarWinds formula for calculating NET-SNMP Memory also comes back negative. Yet when I talk to support they keep telling me that RHEL7 should work just fine for SNMP polling, but then suggestion I try the agent. So is anyone using net-snmp and seeing accurate numbers? I just want to know if it's something on our side with a configuraiton or if this is a known issue. I can't seem to get a solid confirmed answer from support and they just keep sending me links to documents that I'm well aware of....
