I am Install Win 2K3 SP2 Enterprise Edition Service Pack 2, v.4478, MSSQL Server2K8 SP2. After that I installed NPM SLX 9.5 SP2 and just before and of the installation I got this message:
Database configuration failed: Failure importing sample map
Please help!?
HW:
Product Name ProLiant DL380 G3
Processor Package 1 (Socket 1, Core = 1) Intel Xeon Processor @ 3.06 Ghz
Processor Package 2 (Socket 2, Core = 1) Intel Xeon Processor @ 3.06 Ghz
Operating system environment Microsoft(R) Windows(R) Server 2003, Enterprise Edition, Service Pack 2, v.4478 (Build 3790)
Total memory - 10240 Mbytes
Board 0
DIMM 1 ( DDR ) 2048 Mbytes (266 MHz)
DIMM 2 ( DDR ) 2048 Mbytes (266 MHz)
DIMM 3 ( DDR ) 2048 Mbytes (266 MHz)
DIMM 4 ( DDR ) 2048 Mbytes (266 MHz)
DIMM 5 ( DDR ) 1024 Mbytes (266 MHz)
DIMM 6 ( DDR ) 1024 Mbytes (266 MHz)
ECC memory installed Yes
Hardware PAE enabled No
Communication
Serial Port 1 (Address 3F8h)
USB Device 1 USB UHCI Root Hub
USB Device 2 ServerWorks (RCC) PCI to USB Open Host Controller
Network Controller 1, Slot 0 NC7781 Gigabit Server Adapter
Network Controller 2, Slot 0 NC7781 Gigabit Server Adapter
Network Controller 3, Slot 1 NC1020 Gigabit Server Adapter
Storage
Diskette Drive 1 HighDensity 1.44
Optical Drive 1 TEAC CD-224E at Primary/Master
Physical Hard Drive 1, Controller Slot 0 36.4 Gbytes 10K RPM - COMPAQ BD03685A24
Physical Hard Drive 2, Controller Slot 0 36.4 Gbytes 10K RPM - COMPAQ BD03685A24
Physical Hard Drive 3, Controller Slot 0 72.8 Gbytes 10K RPM - COMPAQ BD07286224
Physical Hard Drive 4, Controller Slot 0 72.8 Gbytes 10K RPM - COMPAQ BD07286224
Physical Hard Drive 5, Controller Slot 0 72.8 Gbytes 10K RPM - COMPAQ BD07285A25
Tape Drive 0, Controller Slot 0 HP C7438A
Logical Disks
C: Logical Disk 1 ~ 36.41GB
Logical Disk 2 ~ 145.66GB
PCI Slots
PCI Slot 1 In Use
PCI Slot 2 Available
PCI Slot 3 Available
Error Web site:
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.ServiceModel.CommunicationException: The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue. Local socket timeout was '00:01:00'. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.ServiceModel.Channels.SocketConnection.ReadCore(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout, Boolean closing)
--- End of inner exception stack trace ---
Server stack trace:
at System.ServiceModel.Channels.SocketConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
at System.ServiceModel.Channels.DelegatingConnection.Read(Byte[] buffer, Int32 offset, Int32 size, TimeSpan timeout)
at System.ServiceModel.Channels.ConnectionUpgradeHelper.InitiateUpgrade(StreamUpgradeInitiator upgradeInitiator, IConnection& connection, ClientFramingDecoder decoder, IDefaultCommunicationTimeouts defaultTimeouts, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.SendPreamble(IConnection connection, ArraySegment`1 preamble, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.DuplexConnectionPoolHelper.AcceptPooledConnection(IConnection connection, TimeoutHelper& timeoutHelper)
at System.ServiceModel.Channels.ConnectionPoolHelper.EstablishConnection(TimeSpan timeout)
at System.ServiceModel.Channels.ClientFramingDuplexSessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at System.ServiceModel.ICommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Channels.LayeredChannel`1.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.SecurityChannelFactory`1.ClientSecurityChannel`1.OnOpen(TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.DoOperation(SecuritySessionOperation operation, EndpointAddress target, Uri via, SecurityToken currentToken, TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionSecurityTokenProvider.GetTokenCore(TimeSpan timeout)
at System.IdentityModel.Selectors.SecurityTokenProvider.GetToken(TimeSpan timeout)
at System.ServiceModel.Security.SecuritySessionClientSettings`1.ClientSecuritySessionChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open()
Exception rethrown at [1]:
at System.ServiceModel.ICommunicationObject.Open()
at SolarWinds.NPM.Common.NPMBusinessLayerProxy.Connect(String host, String port)
at SolarWinds.NPM.Common.NPMBusinessLayerProxy..ctor(String host, String port, HandleBusinessLayerException exceptionDelegate)
at SolarWinds.NPM.Common.NPMBusinessLayerProxy.TryToConnect(String host, String port, HandleBusinessLayerException exceptionHandler)
at SolarWinds.NPM.Common.NPMBusinessLayerProxy.CreateNPMBusinessLayerProxy(HandleBusinessLayerException exceptionHandler)
at NetworkObjectControl.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
MSSQL Server 2K8:
Overall summary:
Final result: Passed
Exit code (Decimal): 0
Exit message: Passed
Start time: 2009-07-13 09:40:24
End time: 2009-07-13 10:01:57
Requested action: Patch
Instance MSSQLSERVER overall summary:
Start time: 2009-07-13 09:43:45
End time: 2009-07-13 10:01:45
Machine Properties:
Machine name: XXXX
Machine processor count: 4
OS version: Windows Server 2003
OS service pack: Service Pack 2, v.4478
OS region: United States
OS language: English (United States)
OS architecture: x86
Process architecture: 32 Bit
OS clustered: No
Product features discovered:
Product Instance Instance ID Feature Language Edition Version Clustered
Sql Server 2008 MSSQLSERVER MSSQL10.MSSQLSERVER Database Engine Services 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 MSSQLSERVER MSSQL10.MSSQLSERVER SQL Server Replication 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 MSSQLSERVER MSSQL10.MSSQLSERVER Full-Text Search 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 MSSQLSERVER MSAS10.MSSQLSERVER Analysis Services 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 MSSQLSERVER MSRS10.MSSQLSERVER Reporting Services 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Management Tools - Basic 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Management Tools - Complete 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Client Tools Connectivity 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Client Tools Backwards Compatibility 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Client Tools SDK 1033 Enterprise Edition 10.0.1600.22 No
Sql Server 2008 Integration Services 1033 Enterprise Edition 10.0.1600.22 No
Package properties:
Description: SQL Server Database Services 2008
SQLProductFamilyCode: {628F8F38-600E-493D-9946-F4178F20A8A9}
ProductName: SQL2008
Type: RTM
Version: 10
SPLevel: 1
KBArticle: KB968369
KBArticleHyperlink: http://support.microsoft.com/?kbid=968369
PatchType: SP
AssociateHotfixBuild: 0
Platform: x86
PatchLevel: 10.1.2531.0
ProductVersion: 10.0.1600.22
GDRReservedRange: 10.0.1000.0:10.0.1099.0;10.0.3000.0:10.0.3099.0
PackageName: SQLServer2008-KB968369-x86.exe
Installation location: d:\f54e0049e45c17a3ee04d8c8656d\x86\setup\
Updated product edition:
Instance Edition
MSSQLSERVER ENTERPRISE
User Input Settings:
ACTION: Patch
ALLINSTANCES: False
CLUSTERPASSIVE: False
CONFIGURATIONFILE:
HELP: False
INDICATEPROGRESS: False
INSTANCENAME: <empty>
QUIET: False
QUIETSIMPLE: False
X86: False
Rules with failures:
Global rules:
There are no scenario-specific rules.
Rules report file: C:\Program Files\Microsoft SQL Server\100\Setup Bootstrap\Log\20090713_094018\SystemConfigurationCheck_Report.htm
