I’ve never set up a device with SNMP v3 plus use it in Orion. This is a first for me. We have several video codecs from a vendor named LifeSize and they support SNMP v3.
Here are their only documented SNMP statements to configure on these codecs.
set snmp contact
set snmp description
set snmp enable (disable)
set snmp location
set snmp system-name
set snmp user
set snmp v3trapdestination
get snmp version
Very basic stuff…and as you can see it is not much to work with and I have not been able to make it work using SNMP v3 in Orion.
Can anyone provide any help to understand how this works with Orion’s SNMP v3 settings? Does SNMP v3 still require Port 161?
What about these Orion ADD NODE statements and how they might correlate between Orion & these device SET SNMP commands?
SNMPV3 CREDENTIALS
Username (I assume this comes from SET SNMP USER…)
Context (no idea)
Authentication (no idea) (password/key) Does this come from SET USER?)
Privacy/Encryption (no idea)
READ/WRITE CREDENTIALS
Do these work the same as above?
