Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Problems uninstalling v7 as part of upgrade to v8
FormerMember
If you are experiencing a failure during the uninstall of version 7 or a message stating that version 7 still exists and you are unable to install version 8 or later of Orion, the following procedure should remedy the issue.
Warning: Use caution when editing your Windows Registry. If there is an error in your Registry, your computer may stop functioning. If an error occurs, you can restore the Registry to its state when you last successfully started your computer. For more information, see the Help for the Windows Registry Editor.
1. Run Regedit.exe.
2. Click Edit > Find.
3. Type Orion7NetPerfMon.engine in the Find what field.
4. Click Find.
5. Select the node in the tree that contains the Orion7NetPerfMon.Engine key
5. Select Edit > Delete to delete the folder.
6. Restart your Orion NPM install.
Denny LeCompte
Sr. Product Manager, Orion
SolarWinds
Find more posts tagged with
Accepted answers
All comments
There are no accepted answers yet
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
