I have a bunch of nodes that I want to write a certain Custom Property value for, and then set alerts and group them based on these values.
Or, is there a way to create a group of nodes and enter a Custom Property for all of them at once?
Hi lbrowne--
You have some options here. If you wish to add custom properties to a node in NPM, check out this thread. If you would rather alert based on node groups rather than custom properties, this thread should point you in the right direction.
Hope this helps!DH
Awesome thanks!!! You saved me so much time!
