I'd like to use NetPath to monitor the same IP address and port from multiple APE's, but NPM doesn't appear to allow it.
I have two remote sites hosting APE's.
Each site is connected to a home site via two geographically diverse paths.
The remote sites route MPLS to the home site using two BGP peers--a .1 and a .5. These peer addresses are on two different routers at the home site.
The two addresses reflect diverse paths that have a path distance of 250 miles--significant for latency.
I'd like to use NetPath to monitior the paths and latency to these two BGP peers from different APE's located each of the two remote sites.
I find I cannot do this monitoring in one instance of Solarwinds because NetPath doesn't see a difference in monitoring by source APE when the destination address and port have already been used once elsewhere. I realize I could set a different destination port, but that's not the preferred method.
How can I use NetPath to monitor the same IP address and port from multiple APE's?
