This is sort of dove-tails with the question here: Alerts of individual CPUs in a Node but I wanted to put something fresh out with some more detail. I've put together a custom SWQL alert trigger that will respond to the latest sample of any individual CPU on a node exceeding the threshold in the where clause:
SELECT Nodes.NodeID, CPU.CPUIndex, CPU.AvgLoadFROM Orion.Nodes AS NodesJOIN Orion.CPUMultiLoad CPU ON Nodes.NodeID = CPU.NodeIDJOIN( SELECT NodeID, MAX(TimeStampUTC) AS MaxTimeStampUTC FROM Orion.CPUMultiLoad GROUP BY NodeID) TBL1 ON CPU.TimeStampUTC = TBL1.MaxTimeStampUTC AND CPU.NodeID = TBL1.NodeIDWHERE Nodes.NodeID = 46-- Result:-- 46,0,0-- 46,1,0-- 46,2,11-- 46,3,11-- 46,4,29-- 46,5,29-- 46,6,52-- 46,7,52-- 46,8,0-- 46,9,0-- 46,10,29-- 46,11,29-- 46,12,11-- 46,13,11-- 46,14,64-- 47,15,64
That seems to work fine, but when I write some SQL to use in the alert action message using the same CPUMultiLoad view from the database I get only CPU 0:
SELECT CPU.CPUIndex, CPU.AvgLoadFROM CPUMultiLoad AS CPUJOIN( SELECT NodeID, CPUIndex, MAX(TimeStampUTC) AS MaxTimeStampUTC FROM CPUMultiLoad GROUP BY NodeID, CPUIndex) TBL1 ON CPU.TimeStampUTC = TBL1.MaxTimeStampUTC AND CPU.NodeID = TBL1.NodeIDWHERE CPU.NodeID = 46-- Result: 0, 9
Any thoughts on why the SWQL would be happy but the SQL wouldn't? Am I beating around the wrong bush?
Thanks in advance,
Steven W. Klassen
Programmer Analyst @ Loop1 Systems
http://www.loop1systems.com/
http://www.linkedin.com/in/mrxinu
