I'm so curious event I already set it to 24hours, those 3 still showing the same percentage.. I know because this is real time. but 24 hours is already a long span. why does not make still changes. Is this a bug? Thank you for your response.
I just tested this and found the same results. Not sure why. Check with support.
Hi @thehopelessduck ,
Sorry to warm this up again, but I've run into the same issue. It seems that the Graphs for Min, Max and Average CPU all show the average load.
I've noticed that the MultiLoad CPU Peak Graph seems to actually show what it's supposed to. The Values shown are consistently higher than the Overall Peak CPU Graph.
Did you get anything from support?
Best Regards
Luke
I opened a ticket on this issue. Support after 2 weeks said that is working as designed. The graphs show the time frame but on the right always shows the real time stats
this really isn't very helpful is it??
