Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Dependencies
jbdorsey
Is there any clean and simple way to have dependencies set on alerts so I don't get flooded with emails when upstream router goes down?
Find more posts tagged with
Accepted answers
All comments
floyd.may
Use the "Alert Suppression" tab when defining an alert. You can define conditions here that prevent the alert from triggering.
Floyd May
Software Developer
SolarWinds.Net
pguenther
I have gotten the Alert Suppression to work, the problem I have is that even though the alerts are suppressed their resets are not. Is this by design?
floyd.may
Creating alert suppression conditions on already-triggered alerts will not reset those alerts; does this answer your question?
Floyd May
Software Developer
SolarWinds.Net
jbdorsey
I guess what I'm looking for is a way to have hierarchical alert suppression for multiple remote sites, without having to create a separate alert for each site. Something along the lines as a generic rule of ‘if remote router is down, supress the alert on the remote switch’.
floyd.may
I understand your use case; however, this would require the Orion Alerting Engine to have knowledge of your network's topology. Orion would need to know that your remote router, if down, would also make your remote switch appear down because it is unreachable. This type of functionality is not avaliable in Orion at this time; the best approach is to set up individual alerts for each of your sites.
Floyd May
Software Developer
SolarWinds.Net
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
