Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Solarwinds NetPerfMon is not supported
astro.space
Hi all,
I ask help you about my problem...
I have finished install Orion Network Performance Monitor, then install IIS and running the configuration wizard completely, after that i open the IIS and try to start OrionNetPerfMon and really the request is not supported. So, i can't configure and running the web server. How about solution for my problem..??!
Please, if anybody ever look like problem above, reply this topic....I'm very hope your response.
Thanks Before,
Rudy
Find more posts tagged with
Accepted answers
All comments
FormerMember
I am encountering the same problem on an XP machine. I reinstalled my OS Completly and I am stuck in the same area I cannot start my website
Jose Quiroz
Network_Guru
XP is a desktop OS, Orion is a SERVER application.
Check the server requirements in the Orion documentation.
Also you should have IIS installed before installing Orion.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
FormerMember
I have talked with customer support at Solarwinds and they are running orion Net perfmon on xp machines. I have tried reistalling everything from formatting my hard drive to installing a new OS. When I open my IIS manager my Netperfmon has a red icon with the word error next to it.
Jose Quiroz
jtimes
Like Network _Guru said "XP is a desktop OS, Orion is a SERVER application"; ALL Orion documentation clearly state "Operating System
Windows 2000 Server or Windows 2003 Server" in the requirements section.
www.solarwinds.net/.../sysreq.aspx
John J. Times
chris.conway
josequiroz, In IIS manager do the following: 1) Right-click on Default website and select STOP 2) Right-click on NetPerfmon website and select START But as both Network_Guru and jtimes have said, you should really run Orion on a server.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
