Hi
So I have added 4 UDP's for Palo Alto and the 'Test' function on each one within the UDP application passes and shows me an expected result.
I have tried Get, Get Next and Get Table.....my assumption is the Table one as its a text value.
I have added them into the Orion Node web view as Table, Chart and Gauge but nothing shows up.
The best I can get is to add the Univeral Device Poller Status view and this shows all 4 UDP's with a '1 value(s)' but doesn't actually show me the value!
Have I missed something?
It must be a Tabular Get as (for example), the Test Value for 'panMgmtPanoramaConnected' should show 'Connected' as it does when I do a test.
