In the pop up view it shows this:
"Installation instructions
1. Stop all Orion services.
2. Copy the Orion.AgentManagement.1.6.0.347.opkg file to <orion_folder>/Packaging/Repository.
3. Backup the <orion_folder>/Packaging/Roots/OrionCore.Packaging.roots file.
4. Edit the <orion_folder>/Packaging/Roots/OrionCore.Packaging.roots file and update the following line :
to
Note: If you have Orion Agent hotfix 1, the original version number may be different.
5. Run the Configuration Wizard.
Orion agents will receive updates when they connect to the Orion server, and the issues addressed in this hotfix no longer occur once the agent is updated."
In the actual downloaded zip file the readme shows:
2. Copy the Orion.AgentManagement.1.6.0.347.opkg file to <ORION_FOLDER>/Packaging/Repository.
3. Backup the <ORION_FOLDER>/Packaging/Roots/OrionCore.Packaging.roots file.
4. Edit the <ORION_FOLDER>/Packaging/Roots/OrionCore.Packaging.roots file and update the following line :
"<requires id="Orion.AgentManagement" version="[1.6.0.331,]" />"
to
"<requires id="Orion.AgentManagement" version="[1.6.0.347,]" />"
