Hello,
I am having an issue installing 32 bit Java on 64 bit machines. The package works when run manually, but when pushing it through EminentWare, I get a " Install failed. Fatal error during installation HRESULT: 0x80070643 ". Since the package works manually when calling packageboot.exe, I am at a loss on what is wrong. The 64 bit version installs without issue and basically has the same options, just the 64 bit installer.
Thanks!
