Hello
Version info:
| Package | Orion Network Performance Monitor V8 SL500 |
| Version | 8.5.0 |
| Release | Orion Version 8.5 - August 2007 |
I have setup this folowing the admin guide.
Is it possible to setup alerts to remote web browsers?
Like this:
Configuring Audible Web Alerts
When browsing the Orion Network Performance Monitor website, audible alerts can be sounded whenever new alerts are generated. When enabled, you will receive an audible alert the first time, after login, that an alert is displayed on the page. This alert may come from either an alert resource or the Alerts view. You will not receive audible alerts if the Alerts view or the alert resource you are viewing is empty.
Following the initial alert sound, you will receive an audible alert every time an alert is encountered that was triggered later than the latest alert that has already been viewed. For example, a user logs in and sees a group of alerts having trigger times ranging from 9:01AM to 9:25AM. The user will receive an audible alert. If the user browses to a new page or allows the current page to auto-refresh, a new alert will be sounded if, and only if, an alert is then displayed that has triggered later than 9:25AM.
To enable audible web alerts:
1. Log in to the Orion NPM Web Console as an administrator.
2. Click
Admin in the top menu bar.
3. Click
Account Manager from the left pane menu.
4. Select the account that you want to configure, and then click
Edit.
5. Select the sound file you want to play when new alerts arrive from the
Alert Sound list.
