I would like to select a few sample nodes from NPM and export all of their properties to be used as a template when adding new nodes. (Or to restore/undo the node after it is removed)
The only thing close to that I found was "Export custom property values" after selecting a node under "Manage Nodes":
However after expanding the advanced section, several of the available properties are actually node specific statistical data:
Is there a SWQL query that would yield the type of properties from an existing node which I could use build a "add node" template to be used with CRUD operations.
