Can someone help me create an alert?
I want to have an alert email me when, the Node availability is less than 99.9% for more than 24 hours.
I dont see an "availablity" field in the conditions...
Sounds like a SQL based alert to me. Maybe one of our SQL guru users can chime in?
Does anyone have any ideas on this?
Nhicks--
I'm going to move this to our Alerts forum so that (hopefully) it will get more posts.
M
You could look at the Orion.ResponseTime table which has the Availability field as well as the PercentLoss.
Depending on you interface, this is the query you would want to have:
SELECT NodeID, DateTime, Archive, AvgResponseTime, MinResponseTime, MaxResponseTime, PercentLoss, Availability
FROM Orion.ResponseTime
WHERE NodeID = 28
AND DateTime = (SELECT max(DateTime) as DT FROM Orion.ResponseTime
WHERE NodeID = 28 AND Availability = 100)
The above query gives you all the data for the last time the Availability was 100, if your DateTime is more than 24 hours old, you can alert on that.
I have had issues with the < and > in Perl so you could assume if the Availability = 100 longer than 24 hours ago, then the Availability has been something less than 100.
Hope this helps.
