Hi:
I´m looking for a way to execute this in sql:
select keepalive from engines;
select getdate();
if difference (in minutes) between keepalive and getdate >= 2 minutes
send me an email.
Is this possible ?
Thanks.
Are you using a SQL Server trigger. If you've set up SMTP, then the following trigger might work (I haven't tested it). Be careful though. I don't know how often that table is updated.
USE [NetPerfMon]GOSET ANSI_NULLS ONGOSET QUOTED_IDENTIFIER ONGO
CREATE TRIGGER [dbo].[upd_Engines] ON [dbo].[Engines] AFTER UPDATEAS BEGIN SET NOCOUNT ON;
IF UPDATE(KeepAlive) BEGIN DECLARE @keepAlive as datetime; SET @keepAlive = (SELECT inserted.PICKINGSEQ FROM inserted); DECLARE @liveMinutes as int; SET @liveMinutes = DateDiff(n, @keepAlive, GETDATE()); IF @liveMinutes >= 2 BEGIN DECLARE @serverName as varchar(50); SET @serverName = (SELECT inserted.ServerName FROM inserted); DECLARE @body1 varchar(100) SET @body1 = 'Server :'+ @serverName+ ' keepalive is ' + CAST(@liveMinutes as nvarchar(10)) + ' minutes.' EXEC msdb.dbo.sp_send_dbmail @recipients=';myemail@myserver.com', @subject = 'KeepAlive Message', @body = @body1, @body_format = 'HTML' ; END ENDEND
GO
