Do you have a template you use successfully with a Cisco 5508 Wireless Lan Controller? I'd sure appreciate seeing it.
The 5508 gives you plenty of options to declare ahead of time, and I built them into the script. But they stay in the 5508 unless someone changes them, so I shorted the script line to this:
<Command Name="DownloadConfigIndirect" value="transfer upload start${+CRLF}"/>
NCM errors out after that command, and I believe it's happening because the prompt changes from > to ) as the Controller asks
Are you sure you want to start? (y/N)
I've tried a few tricks without success yet, and have a ticket opened with SW. But if someone out there could share their template with me, I'd be grateful.
Maintaining control . . . for now.
Rick
